ZONE Library
I am using the Special Edition Library 9 and I am getting a 'missing part' error when I start the program specifically "Zone Stamps / Zone Identifier 2". Can someone tell me where / what I need to add to the library to correct this? I looked in the HELP section but there is no section for error messages.
THANKS!
6 Replies 6
This report just means that one (or more) of your zone categories is defined to use the Zone Identifier 2 as its zone stamp. Rather than load unnecessary zone stamps (unless you really do need this one) you can just delete or redefine the zone categories. You will find the dialog for this in the Options menu. It may be in a sub-menu for "Attribute Settings" (or something like that) depending on the work environment you are using.
THANKS for the quick response - its fixed.
Da3dalus
I've got a similar issue with Zone Stamps. My Library Loading Report comes up that I'm missing the part "Zone Identifier" (I'm using the AC10 Library). However, I have checked my Zone Categories, and NONE of them use this stamp. I also checked this in the Attribute Manager, which shows the same thing. Is there anywhere else a reference to a zone stamp could occur? Could it have snuck in with a legacy library part?
It's really not much of a problem; I just HATE the loading report coming up.
Chuck Kottka
Orcutt Winslow
Phoenix, Arizona, USA
ArchiCAD 25 (since 4.5)
Macbook Pro 15" Touchbar OSX 10.15 Core i7 2.9GHz/16GB RAM/Radeon Pro560 4GB
I have the same problem........ did you manage to get it fixed?
There does seem to be a bug with the library loading report that it sometimes reports zone stamps missing that aren't in use. I have seen it occur (at random?) in some projects, but haven't had time to sort it out. As long as the zones are set up as you want them there is no problem created. I think I've seen this mentioned elsewhere, and as I recall the word was that GS is aware of the problem.
has anyone found a solution for this problem? at the very least, is there a way to delete unused zone stamps?
