Project data & BIM
Zone schedule merges items wrong (with library part parameters)
Salto
I want to sum areas by house numbers.
I have made two scedules (see the image):
In AC26 the scedule is correct. I can see all houses and their areas (the areas are merged items).
In AC27 the scedule is incorrect. I have houses H0, H1, H2 and H3 but the scedule only shows H0.
I quess the problem is with zone library part parameters, but why?
I have had the problem in AC26 too. It's random.
What are your merge settings in the column headers? Maybe these are off.
You can change them by enabling "Merge Items" and then click in a column header in the schedule and then on the merge icon that appears in the column header (nr. 2 in the screenshot).
I think you'd need "Unique Values" & "Uniform Values" for the "House Number" column and "Any Values" & "Sum of Values" for your "Volume" column.
For a detailed description check this article by GS.
Let us know if that fixes it or if the issue persists.
Bernd
Automating Archicad with Add-Ons, GDL-Objects & Python Archi-XT.com
Salto
Same problem with different schedules where I use house numbers:
Bernd
Salto
Yes, this solved the problem. Thank you!
I didn't know there are these buttons in the header row.
Setup info provided by author
