Steve
Zone stamp show different information on different sheets
I am looking to turn on and off content visibility of room zones per sheet. ie: occupancy for our code sheet; room finish for our room sheets, and just room name and number on all other sheets. Thanks
5 Replies 5
Steve Jepson
that's a tricky one.
I think it should be possible by use of the Scale Sensitivity Display for the Zone. Zone Content at 1:50 for example can be different than at 1:100.
Different Views would have different scale sensitivity but you may be able to compensate for that by resizing the Drawing in Layout. ?
Lingwisyer
Guru
If you did do that, you will have to be wary of your MVO as that might change with your scale if it is not set.
Ling.
Steve Jepson
Good point Ling,
I haven't tried to do it yet. I am not 100% sure if if works or not. Better option might be to forget doing that with the zone stamp and use some labels. ?
DGSketcher
Legend
There is an MVO controlled zone stamp available from Applecore Designs (UK). I haven't used it myself, but it may be worth investigating and there is a demo version.
https://store.applecoredesigns.co.uk/global-zone-stamp
Erwin Edel
The Dutch subscription library offers this with Model View Options. You can set the zones to follow Model View Options and control for each model view which information the zone shows, which font size, how the text is alligned, etc etc
Just a matter of setting up views with different Model View Options after that.
So it is definitely possible with the right zone stamps and Model View Option library parts.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
