Project data & BIM
Zones with different materials
How can I apply different materials to different Zones?
eg. I want Zone 1 on layer x with material y and Zone 2 on layer a with material b.
I just can't get it to do it, whenever I change the material for any zone it changes it for all the zones.
Djordje
Try Categories
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Up to 11 you could do it individually, selecting the Zone/s, from the zone tool settings. I hope that didn't change in 12.
Link
In AC12 the Zone material can be individually set in Model tab of the Zone Settings dialog as per previous versions. You can set a material for the whole zone, or inherit the materials of the surrounding walls (and trimming elements; columns, roofs, SEOs, etc).
The Zone Color (that shows up on floor plan) is set per Zone Category in the Options> Element Attributes> Zone Categories dialog.
Link.
