Showing results forΒ
Search instead forΒ
Did you mean:Β
Search instead forΒ
Did you mean:Β
calculating materials...
hello!
the question is simple:
my extrior walls are composite with 2 layers: 25 cm brick + 5 cm insulation.
how could i make a list of materials wich will provide me the quantity of brick measured in cubic metres and the insulation in square metres?
1 Reply 1
Have you tried using property scripts.
If you havent tried them, read the basics from the help files and ask for more help here.
The basic procedure will be add 2 entries in the property script.
One for bricks (witch will be based on surface of wall) and will result in number of bricks, and insulation witch will be the same..
Simple.. Try it.
