ā2014-06-08
09:28 PM
ā2023-05-30
12:40 PM
Rubia Torres
ā2014-06-08 09:34 PM
another Moderator
ā2014-06-08 10:23 PM
ejrolon wrote:
Yes. That is why you create "Layer Sets" and "Saved Views".
When you saved your sections to placed them on layouts you had to choose a Layer Set for that Saved View at a later date if you edit that Layer Set to turn the Furniture off then all drawings that use that Layer Set will automatically (on update) turn them off.
ā2014-06-08 10:44 PM
another Moderator
ā2014-06-08 11:04 PM
ejrolon wrote:
Time to start reading:
A placed drawing in Layout has specifc settings that you assign. These include layer sets, scale, line weight, dimension settings etc. If these settings are correctly defined then if you edit the relevant one all the drawings that are "connected" to it will change.
links:
http://helpcenter.graphisoft.com/guides/archicad-17-int-reference-guide/interaction/navigation/navig...
http://helpcenter.graphisoft.com/guides/archicad-17-int-reference-guide/configuration/attributes/lay...
and a tutorial video
http://helpcenter.graphisoft.com/videos/interactive-training/archicad-training-series/archicad-train...
ā2014-06-08 11:07 PM
another Moderator
ā2014-06-08 11:10 PM
another Moderator
ā2014-06-08 11:11 PM
another Moderator
ā2014-06-08 11:13 PM
ā2014-06-08 11:18 PM
ejrolon wrote:
It is something you can do after the Views are placed on the layouts. To assign a Layer Combination to different drawings.
Right click on all the drawings either by page or using Navigator View map and edit the Layer Combination
