2025-07-21 08:41 AM
Hi everyone,
I have a custom property that displays the diameter of openings in my project.
In schedules the values come trough and are shown, but in my plans they do not. I only get the property name shown in my label.
Does anybody know what could be the issue?
Cheers
Operating system used: Windows 28.2.1 (5101)
2025-07-21 09:15 AM
Hi!
A few possible issues I can think of:
Please double check this points and let us know if the issue still persists.
2025-07-22 09:55 AM
Ive checked and:
- label is connected
- classification is not an issue since the values come trough in schedules
Ive simplified the expression which made the property work for different kinds of openings. It reads the opening shape and based on this returns the hole ϕ or b/h value with added prefix and suffix. I took out the IF statements relating to opening shape and the expression works in schedules and labels too.
Curious one...
2025-07-23 08:16 AM
That's weird. The opening shape is available in labels (at least in AC28 which I tested):
Can you share your expression for us to try?
And which AC version are you using?
2 weeks ago - last edited 2 weeks ago by Barry Kelly
Sorry for not replying. The problem still persists:
In the screen capture above you can see the label, where the bottom line should display the property value. On the left we have element properties tab where property value is displayed correctly (blue highlight).
Im using AC 28.3.0. (6000) INT
This particular property and others that read element dimensions and format them into appropriate format depending on element type & shape worked when I created them. Ive tested them in plan and schedules at least. Must be something I did in the template that broke the property value display in autotext label. What could it be?
Property also works in property manager if I click "Evaluate...":
2 weeks ago
It's a bit tough because I'm not familiar with your language.
Does 'd1 - stebri in preboji' work in labels?
Could you export your expressions and upload here for us to test?
Best,
Bernd
