does AC have a Select freeze button?
does AC have something similare to a freeze selected button?
IE, select an item and push the button and it will freeze out the layer that item is on?
would be so much easye rand faster then Ctrl L find layer freeze back to work.
19 Replies 19
Erich
Yes, look at the quick layers pallet.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
right click menu?
Erich
xristina wrote:
right click menu?
True. And this can work well, but there are slight differences. See the following article.
http://aec.cadalyst.com/aec/Column%3A+ArchiCad/Quick-Layers-Palette-ArchiCAD-Insights-Tutorial/Artic...
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
You can also lock individual elements and not just entire layers (in the EDIT menu).
I find the QuickLayers palette indispensible. Not sure if I could/would work without it. As mentioned in older threads, the QuickLayers palette does not interact with the WorkEnvironment properly - and so its visibility and position is not 'remembered'. Because of that, I assign a shortcut key to toggle its display. (Since cmd-L is layers, I use cmd-shift-L for QuickLayers.)
The only time I've found this useful was when marquee-stretching to keep certain elements from being stretched. E.g., locking the wall layer won't help if you want to stretch some, but not all, walls. Have you or others found good uses for locking individual elements?
karl
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Erika Epstein
karl
Yes, I do this often so I have short cut keys to lock and unlock.
And lets not forget that it was Karl who came up with the idea of and taught us all how to make the QUICKLAYERS palette. It was such a fabulous work smart idea that Graphisoft added as a standard!
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Thanks, Erika. But, did I? Old and forgetful that I am, I'm not sure that I did? I did do that add-on for AC 9 which became unnecessary in 10 when GS gave us the 'On Screen View Options' toolbar. But, I don't remember doing a QuickLayers-type thing...?
Karl
Erika Epstein
Old and forgetful am I I was thinking of your QuickDisplay tool. It did open up another world for many of us to be able to create our own toolbars and that was an advance from 10 onwards which included a Quick Display tool bar.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Thanks, Erika. But, you don't get to play the old card ... however old you get, I'll always be older. 😉
K
