Project data & BIM
does AC have a Select freeze button?
does AC have something similare to a freeze selected button?
IE, select an item and push the button and it will freeze out the layer that item is on?
would be so much easye rand faster then Ctrl L find layer freeze back to work.
19 REPLIES 19
Karl wrote:
Have you or others found good uses for locking individual elements?
I don't use this very often but it does come in handy when there is something that you know shouldn't be moved/stretched.
And as you say it is sometimes handy to not have to lock the whole layer.
Personally though I tend to work without locking items or layers.
It's a bit like grouping.
A very handy feature but I am just used to working without it most of the time.
David Maudlin
When placing a scan of a site plan, after getting the size, rotation angle and placement correct, I lock it down.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
site boundaries, level dimensions on plans, site meshes... grids....
many things
I nail everything down that is not supposed to move like grids
and any meticulously placed elements.
rgarand
I know this is an older thread, but what I am looking for is similar and in line with this discussion.
I am looking for a shortcut to turn a certain set of layers ON. For instance, I have a layer for Hidden Section/Elev markers. When I switch (using view maps) these layers go away. I know I can switch stories/views using the project map and the layer visibility will not change...I do this in some cases. I just find myself wanting to turn on certain layers as I am working.
Thoughts?
Rob
Robert J. Garand
ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
sinceV6
Does making a "work" or something layer combo and saving a new view helps? This way if you switch using your standard view and your layers go away just click the work view and your layers are back.
rgarand
Yes, this would work and I have experimented with this. I just think a "1 key" shortcut would be much more efficient. I like my fast short cuts.
Robert J. Garand
Stress Co_
With simple addon you can have a layer palette always open. One click to open/close layers.
Marc Corney, Architect
Red Canoe Architecture, P. A.
rgarand
Thanks for the link Marc. I am really looking for something I can use as a "1-key" shortcut. When I need to move around a screen with my mouse, scroll through 100 layers and then click 5 times to turn on 5 layers...this to me is not efficient.
Robert J. Garand
I just make a layer combination for what ever I need.
Then when I change views and I want to see the section lines again then it is just one click on the Quick Options Palette and choose from the list.
