drawing is gone
Helo
Yesterday I saved my project and this morning when i opend it, the only thing I saw was a whit space. Only the plans that are in the layout (for plotting) I can see, but nothing on the stories. (all layers are active and visible)
The same problem in the '.bpn'
In the controlbos the values of X,Y,R ans A gives "****" and the scolbars doesnit function.
I use Archicad 10 815 INT FULL
HELP HELP
Thomas Holm
I guess your model is too far from the origin. Common problem if you've imported or hot-linked/ xrefed a slightly-off DWG file. They may have dots (usually converted "insertion points") that are very far off from the rest of the model.
1. Show all layers.
2. Zoom to Extents. Zoom out even further.
3. Arrow tool, Select All.
Now you should see whatever contont you have highlighted. Locate and zoom in.
Then try exploding and deleting the unneeded content that is off.
