2009-06-03 08:44 PM - last edited on 2023-05-26 09:01 AM by Rubia Torres
2009-06-04 01:43 AM
2009-06-04 01:22 PM
2009-06-04 07:39 PM
Grass wrote:You are being a bit hasty in condemning hot-linked modules; this is an important and wonderful method for working smart. Learn about correct methods for maintaining and transferring attributes.
I actually just found the problem. In the hotlink, I updated the composite wall in question (I increased the air space in a cavity wall). In the documentation file (where I am hot-linking in the module) there was a default composite wall with the same name. So the documentation file was not reading the updated wall thickness. Once I deleted the composite wall in the documentation file - the updated wall was restored. I find this logic absolutely absurd and I am not convinced that hotlink modules are a productive way of working.
2009-06-04 11:35 PM
Grass wrote:On the contrary, I find it reassuring that it works this way. Assuming that the naming of the walls had been deliberate, this means that the special case (the unique wall) in a file where an instance of the general version (the module) is placed (hotlinked), has priority.
... In the hotlink, I updated the composite wall in question (I increased the air space in a cavity wall). In the documentation file (where I am hot-linking in the module) there was a default composite wall with the same name. So the documentation file was not reading the updated wall thickness. Once I deleted the composite wall in the documentation file - the updated wall was restored. I find this logic absolutely absurd and I am not convinced that hotlink modules are a productive way of working.
2009-06-05 04:58 PM
2009-06-06 11:18 AM
