‎2014-09-14
08:30 AM
‎2023-05-25
06:32 PM
Rubia Torres
‎2014-09-15 09:00 PM
‎2014-09-15 09:19 PM
"NCornia" wrote:
Kamelite,
At this time you will need to either have identical story settings in both module (Mod or PLN) and master PLN or you should use a method to bring in the module as an element hosted on a single common story.
Are you trying to hotline a building into a site alongside another building or is it a situation where you are hotlinking repeating rooms such as in a hotel or hospital?
If it is the former situation then you should employ a method to bring the building in as a single story element and place it at the appropriate height. One such workflow would be to save the entire building from the Hotlink as a .GSM object and place the object in the master project. As the module model changes you can re-save the .GSM and overwrite the previous one to update the master project.
For the latter situation you can import the hotlink module and choose which story of the Hotlink corresponds to the story in the master project.
We actively discuss the need for more flexible story handling between project files. I will add your post to our next meeting about desired features. Thank you for the post.
Best regards,
‎2014-09-22 07:53 AM
NCornia wrote:Yes please! Not only the ability to handle storys better, but also Solid Element Operations. I recently had huge problems when I did a project consisting of two buildings on adjacent sites. I modeled each building in its on PLN file, using the same story levels in each file, but when they were hotlinked together, all the SEO's were disregarded and I had a mess!
Kamelite,
Best regards,
‎2015-06-04 12:04 PM
NCornia wrote:
Kamelite,
Best regards,
‎2016-03-17 10:31 PM
‎2017-02-20 03:11 PM
NCornia wrote:IS there any news on this to be adjusted in future ArchiCAD.
Best regards,
‎2017-04-20 03:13 AM
‎2017-04-20 04:38 PM
‎2017-04-22 04:26 AM
