image projection
why is the siding tan 6" horizontal (model attributes ) not showing in the photorendering projection? it is only showing a flat tan colored siding with no horizontal 6" .
please help.
ac7
12 Replies 12
screen shot of model attributes.........
screen shot of model........
it's in the 3d window setting.....
Steve Jepson
please help.
ac7
Probably the Material setting.
(Options/Materials/Edit Texture)
You may need to reload the library.
Your screen shot of the wall settings indicates that siding tan 6" currently only has a vectorial hatch assigned to it. As the previous message, go to materials and assign a texture, which will then be visible in both OpenGL and photorender. Your wall setting will then show a little picture next to the material to indicate that a texture is assigned.
Steve Jepson
He is using version 7. No OpenGL ?
__archiben
kev's right - openGL or not, the material texture shows in the photorendering window when the texture has been applied to the material.
follow the steps in the post above . .
~/archiben
b e n _ f r o s t
Steve wrote:
please help.
ac7
Can anyone provide me the Texture for the siding so I can applied to the setting? I have checked the bundled I got in the AC7 and there is nothing on siding or maybe I miss it somewhere else.
OK- I got it ....but still can anyone share a cedar split siding texture?
thanks
