Project data & BIM
info box layer drop down menu custimization
Dave Brach
How do I get the layer drop down menu to show only the layers that are visible in the layer combination for the current view?
Dave Brach/architect AC28 Macbook M4 Pro OS Sequoia
1 REPLY 1
The only filtering available for the layer drop-down is to hide 'locked' layers. There isn't an option to hide invisible ones.
So, you could change the settings for your layer combos so that all invisible layers are locked to achieve what you're asking for. But, this does then make it hard to quickly move something to an invisible layer (e.g., hidden cutting object layer, recycle bin layer, etc)... so you might want to leave a few key hidden layers unlocked.
Hiding locked layers from the drop-down is a setting in the Work Environment...see attached.
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
