β2013-06-28
09:45 PM
β2023-05-26
03:21 PM
Rubia Torres
β2013-07-01 06:54 PM
β2013-07-02 09:20 AM
β2013-07-07 01:51 PM
β2013-07-07 05:40 PM
MarkMoscrip wrote:try opening the default ac 17 template file. then open the layers and change one or two of them to have different priorities. then open the attribute manager and save the layers and layer combos in an .att file. close and reopen the attribute manager, open the newly saved aat file and overwrite the layers and then combos. does it still be have properly?
I just opened a blank project with AC17 default template and used the default visualization profile. Using Attribute manager I opened an AC16 file and overwrote all layers and layer combos of the AC17 originals with my AC16 aat values.
All behaviors of layers and priorities are fine. No resets. I am able to use, close, reset individual priorities and also sort by priorities without any odd behavior.
Secondly I used Att Mgr to import ONLY the layer combos from an AC14 file. Still no odd behavior. NOTE: I am importing attributes from the full pln, not a saved aat file. I presume you are importing atts from a plt file, could be the plt behaves differently than a pln in this instance.
β2013-07-07 09:04 PM
β2013-07-07 09:10 PM
β2013-07-08 03:56 AM
thepsyntyst wrote:When you are changing the layer priority number are you also updating the layer combos as well?
try opening the default ac 17 template file. then open the layers and change one or two of them to have different priorities. then open the attribute manager and save the layers and layer combos in an .att file....
β2013-07-08 03:04 PM
MarkMoscrip wrote:The thread announcing ArchiCAD 17 Hotfix 1 (build 3013) is here:
PS when I request an update status on my AC USA version I am informed that the 3002 is "up to date". You seem to have a 3013 update, is that right?
β2013-07-08 04:51 PM
