2007-03-17 02:13 AM - last edited on 2023-05-30 01:13 PM by Rubia Torres
2007-03-17 02:14 AM
2007-03-17 06:14 AM
2007-03-17 04:46 PM
2007-03-17 05:14 PM
Matthew wrote:
The first thing to come to mind is that you might have duplicate roofs and floors which are canceling each other out. But as I recall this is a problem in section and causes different effects in 3D. Worth a look though.
It is also possible to specifically exclude elements types in 3D (in one of the 3D view settings, I think it's now called "Filter Elements in 3D"), but it defaults to showing everything but the zones and you would have to change it intentionally, so that seems an unlikely explanation.
2007-03-17 05:21 PM
2007-03-17 07:48 PM
BAS wrote:Maybe it is still duplicates if switching to wireframe and then to solid gets them to show.Matthew wrote:
I dont think that is it
The only way I can get it to show again is to go to the layer settins and change the layer to wireframe, and refresh the view then it shows in wireframe. Then I change it to solid and it works.
I also checked for duplicates
Any other sugestions?
Thanks
Brian
2007-03-17 09:23 PM
laszlonagy wrote:No luck doing that. If there were two exact same elements occupying the same space, would just those two in the same space have trouble displaying, or would every Slab/Roof in the whole plan have trouble not just the duplicates?
The same set of elements may be on entirely different stories, but occupy the same space in 3D.
Try this: select one element and delete it. If it now show correctly, it means that there are two exact same elements occupying the same space, in which case Matthew is right.
2007-03-18 07:42 AM
2007-03-18 04:53 PM
