ā2011-12-19 10:12 AM
ā2011-12-19 12:19 PM
ā2011-12-21 11:26 PM
Krippahl wrote:Dear Miguel,
I am sure you use a Content Plan to go along with the model. In this CP you should state the LOD of each elements, preferably organized by layers.
Postulating on that, I would imagine that using the layer name to indicate de LOD of all included elements would be the easiest way to incorporate that kind of info in the model, and export it into VICO (for instance).
You would have to have a coherent LOD for each layer, which seems to me to be good practice anyway, and when the LOD gets an upgrade you "just" have to change the layer name.
As for colors you could use the same system. Assign specific materials to each layer, and further down the road change the color of the material assigned (for instance through the attribute manager).
Of course, having the ability to include tags on each element would be great, but would also rise the question of interopere... interoperu... interoperabu... exchange between softwares. Thus, it would be a good idea to look into IFC parameters, to see if they are up to the job (pity ArchiCAD 15 does not let you include those parameters in schedules).
ā2011-12-22 10:34 AM
Mats_Knutsson wrote:That is an easy one. Use DWG/DXF translators.
Layers=no no...need to have the correct layer codes for dwg-export.
Mats
