Installation & update
Cannot Save Plan File
This has happened to be twice now on AC13 projects where I am working on a PLN project and when I try to save I get a "CANNOT SAVE PLAN FILE" Error. Save goes for the Autosave. I have plenty of space available and I can not save to another device. My Autosave file shows as zero k as well, so force quitting will lose my work. I will have to try and second copy of the file and copy paste out my work.
Again, this has happened twice on two different machines since AC13 came out and my gut feeling is there is a problem somewhere
6 REPLIES 6
Is it possible that you are trying to save to a location that you either have no access to or it is a read-only folder or something similar.
I mean, can this be some kind of a permission issue?
Has somebody else on the network opened the same file with "Exclusive access"?
Can you do a "Save as" to another location?
I have 2 costumers with the same problem. Both have files that are started in early AC versions. (AC6.5)
The only way they have been able to save is as Archicad 12 Project.
But that really don't solve the problem...
i have had the same error "cannot save plan file"... i am the only one using the file..tried saving to desktop instead of server, tried downsaving to AC12...there was an autosave so i force crashed my computer, unfortunately when it restarted the autosave was gone... i was deleteing dimensions and inserting doors at the tme of the crash, don't know if that helps narrow it down but i hope this isn't going to be an ongoing problem
We have two computers and we have found that there are a few files that continue to say 'Can not save plan file' unfortunately it will not allow us to save them to our own desktop (we work off of a server) so essentially we have to open an old version and copy in the changes that we have made and finally close the file without saving. It could be that it's happening after the file is open but unused for a few days, we do work on multiple files at a time and often leave them open over night, but this has happened on both computers over the last few months.
This is a typical AC13 problem with files that started in earlier versions. We do not have encountered same problem anymore since we use AC14.
Learn and get certified!
