Installation & update
SOLVED!
CodeMeter: Single Licence LAN
Lingwisyer
Guru
Hi all,
Is there a way to setup CM Server to work with single keys? Or does it only work with network keys?
You could apparently do it with WIBU keys but there was no resolution for CM keys. Is this still the case?
https://archicad-talk.graphisoft.com/viewtopic.php?f=7&t=33176&p=173589&hilit=codemeter+server#p1735...
Ling.
1 ACCEPTED SOLUTION
Solution
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Ling,
Thank you for your question!
From my understanding, it is not possible to setup CodeMeter Server to work with single keys, unfortunately. It only works with NET license keys (even NET1 license).
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
1 REPLY 1
Solution
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Ling,
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Learn and get certified!
