When i open the file, a pop up shows an attention message. It says the file can just open with a comercial version. And i´m using a educational version (AC23).
ejrolon wrote:
You'll need to be more specific about the issue since in AC just opening the file and selecting Migrate will 99.99% of the time work.
The actual message should be a warning that indicates that you are "opening a commercial file in an education version and it will change it to educational if you continue…" Just select continue and the file should migrate ok
Edited by Barry
eduardo rolón AIA NCARB Another of the forum moderators. Macbook Pro M1 Max 64GB ram OS X 10.XX latest AC25 US/INT -> AC08
