Project data & BIM
Surfaces folder structure keeps changing size
derekjackson
Hi, we're just getting used to working with AC27 (moving from AC23) and the new folder management for attributes looks like a great improvement at first impression.
However, I've found the constant resizing of the palette hugely annoying. When working with Surfaces, if you click on a Surface it expands to show all the settings, but if you then click on a different folder, the palette shrinks to a level where you can hardly see what Surfaces it contains.
Is there a way to get the palette to stay at a fixed size? When editing a collection of Surfaces I seem to spend half the time resizing the window 😞
http://www.lsiarchitects.co.uk
http://derekjackson.artstation.com
AC19 / 21 / 23 / 27
Windows 7 Intel Xeon 18Gb
2 REPLIES 2
I assume you mean the behaviour where the cineware settings tab collapse when selection a folder - it was reported during AC27 beta but the whole attribute folder functionality was obviously a implement as conceived and move on kind of thing....
derekjackson
😞 Well hopefully someone from Graphisoft will read this and feel inspired to fix it...
AC19 / 21 / 23 / 27
