Installation & update
SOLVED!
Importing Work Environment Not Working
Anonymouse
Trying to import a Work Environment Profile and or a shortcut scheme and the .xml files show up grey and are inaccessible. Any idea of why this might be?
Thanks!
1 ACCEPTED SOLUTION
Solution
Brian Spears
I think when importing a scheme into your Work Environment, you want to browse to the level of the folder that the .xml resides in. Pick that. Then in the next dialog back in Archicad, you'll select the scheme to import.
Brian Spears
BIM Manager, Steele Group Architects
Winston-Salem, NC
AC26 USA on macOS
2 REPLIES 2
Ricardo Lopez
Hi
Try this:
https://www.easeus.com/computer-instruction/how-to-fix-grayed-out-folders-or-files-on-mac.html
Regards.
M. Arch. Ricardo López
AC17-27 SPA+INT | Windows 11 | MSI WE75 9TK, 32GB, Nvidia Quadro RTX 3000
Solution
Brian Spears
Brian Spears
Winston-Salem, NC
AC26 USA on macOS
Learn and get certified!
