Aussie wrote:
I think most use the section tool for a more robust and editable environment
Hey John,
I understand you to mean that because sections are or can be live, they require no additional editing, which I agree with (except if you only want to see the extent of the room without other section info).
What I liked with the auto interior elevation feature (when it worked) is that you could select to view just the room outline or with additional cut elements if desired and have the elevation automatically outlined with a heavy pen. Also, that it would quickly produce all or selected zones elevations with labels in a defined organization; granted that there was clean-up to do. Finally and unless I'm missing something, with the section approach, one ends up with 4 section windows per room typically, which is OK but adds to the Project Map Sections/Elevations sub-directory requiring more info management.
So (going against the grain), I guess I'm saying I liked the speed and organizational aspects of the auto interior feature, and I wish/hope it will be repaired swiftly.
Thanks,
Scott
AC25 v. 5005 w/ MEP, Cadimage, Twinmotion 2021 using AC from AC6.0, 2.7 GHz 12-Core Intel Xeon E5 (OS X 12.2.1 Monterey), AMD FirePro D700 6GB, SSD, Artlantis 2019, Adobe CC. Used AC on both platforms.
