Find the next step in your career as a Graphisoft Certified BIM Manager!
Installation & update
Missing UI
Hello guys, I reinstalled my windows 10 and now I'm stuck with a UI that has no images....
Please help me I don't know what I'm missing but surely there's some extra software that needs to be installed.
https://imgur.com/a/s9NQ51t
8 REPLIES 8
vistasp
When you say "reinstalled windows" do you mean a fresh install or an update/upgrade?
I'd first try to reset the work environment to one of the defaults
If that doesn't work, your best bet might be to reinstall ARCHICAD.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
What I did was I used the "Reset this PC" function to keep my files and data but delete all apps and reinstall windows. On the link below you can see the function I used.
https://imgur.com/a/sIWRmS7
I attempted to change the work environment and the profiles used but the problem remains the same.
Also, I reinstalled archicad many times without any luck.
vistasp
Your preference files are likely to have been damaged by the reset.
1. Uninstall AC
2. Clean out your AC preference files (see https://helpcenter.graphisoft.com/knowledgebase/25464/)
3. Reboot
4. Reinstall AC with security apps like antivirus and firewall turned off
5. Reboot
Do let us know if it works.
= v i s t a s p =
bT Square Peg
I followed your suggestion and I deleted all graphisoft folders as listed in the linked page. I also deleted the registry. After installing AC following your reply, the result is still the same. Originally I thought that maybe I'm missing some Visual C++ Package but I've already installed all of them one by one to make sure I'm not missing something. Maybe there's some other 3rd party software that aids the graphical side of Archicad's UI?
As a note, I managed to install Archicad 17 with properly working UI. Archicad 22 has the same problem as AC 20 and these are the only AC's I've tried.
Bump...can someone please help...I'm in desperation at this point...
I have no idea what would be causing this but I would check that your video drivers are up to date.
Seems odd that 17 is working though.
Have you tried contacting your local Archicad support?
Hello everyone. I decided to try a totally clean reinstall of my windows 10 and that fixed my issues. I still have no idea what caused the problem to begin with anyway but I couldn't afford to waste more time on this bug.
vistasp
It's good to hear that things are working again but must be a pain to reinstall everything from scratch.
Note to self: "Reset Windows is not reliable".
= v i s t a s p =
bT Square Peg
