Mark wrote:
Can someone please take a look at this file. The placed object reads a different Y and X coordinate than it should be. I have tried reseting the origin but still no luck?? Am i missing something basic here?
FYI i you move the object around it will output its X/Y coordinate
Thanks for any help.
Mark,
This object works perfectly fine in my template.
When I open your PLA the object says it is at 0,0 (which also matches with the grid lines).
I also see a quick flash of a ghost-grey origin where your object is but it soon disappears.
Your drawing origin is way off to the left some -189.642, -30.6135 away.
What is strange is the co-ordinate box says this origin is at 0,0 but it doesn't match the backgound grid.
Somehow you origin has been moved but don't ask me how.
It is definitely the default origin.
Try an new and reset or the default graphisoft template and see what happens
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
