Installation & update
missing D1 Transom shutter variables
I'm trying to add a shutter to the D1 Transom door. Problem is - there is no visible parameter for "shutter width".
If I open the part and take a peek, I see the parameter *is* there - it's one of the blue ones (intrinsic to this type of library part?). But when closed and viewed under the normal selection settings dialog - it aint' there!
What could be going on? I'm running X 10.4.1 on a G5 imac. - Thanks.
Attached screen shot of variable list...
2 REPLIES 2
Well (sheepish) I understand now why the "width" variable disappears...
These new Lib parts are very intelligent - the variable list changes with the selection of different shutter types - all good - except if one selects shutter type seven - as I did - the "width" variable disappears!
I can't understand why type seven was intended to be a fixed-width - but the answer is to select one of the other types - then enter the proper width - then return to the type seven selection.
Onward and Upward... maybe this will help another...
leporello wrote:
...Problem is - there is no visible parameter for "shutter width"....
Open "Shutter.gsm" (must be extructed from Object Library 9.PLA)
In Parameter script dialog find( for shutter type=7):
if gs_window_shutter = stShutterStyle[8] then ! solid shutter
hideparameter "gs_shutter_type",
"gs_shutter_width",
"gs_shutter_pos",
"gs_shu_frame_w",
"gs_shutter_w",
"gs_shutter_th",
"gs_shutter_ang",
"gs_shut_fill_typ",
"gs_hor_board_w",
"gs_ver_board_w",
"gs_hor_bn",
"gs_ver_bn",
"gs_board_w",
"gs_board_th",
"gs_shut_frame_mat"
lock "gs_shut_frame_mat"
endif
Deleting Red Marked line will allow you see required option in D-W Settings Dialog.
Learn and get certified!
