2026-07-13
03:17 PM
2026-07-15
10:40 PM
I'm new to Archicad, and trying to figure out the easiest way to do heat loss area (HLA) calculation elevation drawings for extracting data to insert into my PHPP (passivhaus planning package). In Vectorworks, I could use the zone tool on elevations - but it looks like I can't do that here. In Autocad, I'd just go fully manual - but I'd really like to use some smarter workflow here.
Essentially what I need are areas mapped out on an elevation, broken down by type of construction (u-value), with a label marker for that zone included. The area needs to extend to the outer edges of the thermal zone (i.e. bottom of floor slab, top of roof insulation, etc). Sort of like this example image.
I'm aware of the Energy Evaluation tool, but that's a bit off my radar for these early days. My model is a provided measured survey to start with, so no real data in it as yet - and this PHPP is for the existing building.
Googling for help isn't helping! Any tips, nuggets, or helpful pointers would be very, very much appreciated.
a month ago
Did you ever figure this out? I too am new to archicad and am very disappointed in its ability to help with thermal area calculations like this. Have not figured out a way to automatically calculate thermal envelope based on orientation.
4 weeks ago
Unfortunately not. I sat in a presentation by a firm of architects a few months back - they're Passivhaus Designers - and they made a particular point about how they use Archicad to give them the external areas. On that basis, I know it's possible. The How eludes me entirely.
4 weeks ago
So played around with making a morph to the boundary of the thermal envelope. The made surfaces such as north walls, south walls, slab on grade, etc. then you can schedule the surfaces a get the areas to input into Phpp.
