Ecodesigner Installation Error
"No ArchiCad 12 component found at location"
-But im running the installer FROM the precise Archicad 12 location?
Any ideas?
-I did install the newest updates to library, hotfix & ifc.
10 Replies 10
Sorry for the language confusion. No, you do NOT rename anything. If anything IS renamed, the installation will fail. There are too many files to guess which might have been renamed or moved, which is why I suggested re-installing to get it right.
Sorry - no more ideas here - perhaps someone else has one?
Good luck,
