Sustainable design
About EcoDesigner, Energy Evaluation, Life Cycle Assessment, etc.
Ecodesigner does not recognizes my imported .3ds roof
I created a curved roof surface in Rhinoceros, then imported it into the ArchiCAD, by using the .3ds to .gsm convertor.
You can see my roof (white surface) in here:
Now, I want to calculate my whole object in EcoDesigner. But the problem is that, Archicad, simply does not recognize my roof as a valid construction and hear barrier. So it looks like, I do not even have the roof above my upper floor.
How can I fix this? How can I force Archicad to recognize this roof of mine as a barrier?
Or maybe I simply need to put a slab over my upper flor. But in that case I am loosing much of a height of my obejct, because it is in a shape of dome. Take a look at this picture:
And a longitudinal section:
7 REPLIES 7
any reply please?
I'm sure many of the experts are busy beta testing at this time of the year which is why the lack of comments.
TMA_80
Well, it seems that gdl objects are not recognised by ecodesigner...
Have a look at this post :
http://archicad-talk.graphisoft.com/viewtopic.php?t=35516&highlight=ecodesigner
AC12_27 |Win11_64bit|
Thank you for the reply.
By .gdl object, you mean the .gsm object of roof I created from my .3ds file?
TMA_80
Affirmative.
thank you for the help.
TMA_80
You're welcome .
