Arcadia
Ecodesigner - materials
I am using and learning ecodesigner after having just taken delivery of it. My biggest frustration with it is that the materials catalogue does not seem to have much that matches the materials used in Australia or at least the names are different. Therefore its hard to know that what I am picking is the right type. Also allthough with windows I can just overwrite the U-value in the main "openings" tab (which is just as well as there is no option for single glazed windows in the materials catalogue) I don't have this option with the structures tab - ie I have to select the R-value calculator then assign materials to each of the skins in my walls. Lastly as far as I can tell I can't add in my own custom materials to the catalogue for materials that are not available in the list.
I can see the benefits of this software if only I can figure out how to get the accurate R or U values for the materials I am using.
Any help/tips/comments?
V12-V27, PC: Ryzen 9 3950X, 64g RAM, RTX5000, Win 11
10 Replies 10
Arcadia
Another related query is: what are the figures that are shown in the R/U-value calculator? Ie the editable figures down the bottom: heat transfer coefficeint internal and external and the thermal bridge effect. Where do these figures come from, how do I know if they are correct, what do i do with them?
