Sustainable design
About EcoDesigner, Energy Evaluation, Life Cycle Assessment, etc.
Psi value calculation
Miha Nahtigal
I am trying to simulate thermal bridge similar to certified slab-wall connection by passive.de
I've attached the detail mentioned above with Psi=-0.2 W/mK
I cannot come close to the certified Psi value using Ecodesigner as thermal bridge simulator. I've tripple checked every value I use and still get weird results from Ecodesigner.
What am I doing wrong here?
BIMquants.comBETA - Quantities and Costs Estimation in Archicad - BETA testers needed.
6 REPLIES 6
Miha Nahtigal
Ecodesigner's result - Psi=0,36 W/mK
Miha Nahtigal
I am attaching my source file to clarify things a bit:
https://dl.dropboxusercontent.com/u/3128804/PsiCoefficient.pln
Could somebody verify my detail and Psi calculation?
Where might be the problem?
Psi value should definitely be negative in this case. Is there a problem with ground that should be calculated as infinite element?
I think Psi in Ecodesigner doesn't mean Psi but I don't know what does it mean:D If I move border of detail, I'll get the another Psi value and this is not possible. Can this explain anybody from Graphisoft? I thought It could be thermal transmittance of the whole detail, but it isn't too.
May I ask here about an error?
Why does it happen?
Follow the standards which describe how thermal bridge conductivity is calculated. In case of wall/wall for example you must take 3x thickness of construction as its length in the detail. In case of the floor on ground it is 4 meters or a half of building (the bigger value).
furtonb
Hi Vahur,
Could you elaborate a bit more on the standard calculation?
I'm a student of architecture, and I don't have access to standards, and they are a bit pricey for my budget.
I've started looking for reference online, but no luck so far.
According to this post:
https://emu.systems/2015/11/09/thermal-bridges-the-psi-value/
The PSI value accounts for the difference between the simplified 1D heat loss and the simulated 2D loss, if I understand correctly. The PSI value given by ARCHICAD is the L2D in the following equation in the case of a L corner detail:
PSI = L2D - (U1 * L1 + U2 * L2)
And L1 and L2 would be a standardized length?
So the Psi,e and Psi,i values could be calculated with the simulated Psi from ARCHICAD.
Is there an official documentation on this from GRAPHISOFT?
The HelpCenter guide is a bit shallow in this sense.
Anyone to point me in the good direction to put the pieces together?
Thanks!
odv.hu | actively using: AC26-28 INT/HUN - multiple builds | Rhino6-8 latest build | macOS @ apple silicon / win10 x64
