We value your input!
Sustainable design
About EcoDesigner, Energy Evaluation, Life Cycle Assessment, etc.
U Values
Please forgive this newbie question:
I can put the W/mK against each element.
I can use these elements to create a composite surface.
(Except I can't make an element layer that combines timber and insulation)
... so where can I see the 'U' value of the composite?
... and if I use this composite with some openings in it, where can I see the aggregated 'U' value for that element?
David Shorter
HI
you have probably found this already but if not you can find the U values of the surrounding structures by using the Energy Evaluation tool found at the bottom of the Design Menu
Hope this helps
Archicad 4.1 to 28 Tech Preview. Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
Thanks for the kind information
What is the purpose to know the composite wall U-value? If this is for energy demand evalualuation, it must be done manually in ArchiCAD. The tools are not working correct in case of composites, especially in case of ventilated facades and frame walls. The best solution is: to make calculation manually or with special software and then use the U-values applying them to non-composite walls. In addition thermal bridges should be considered. For openings it is quite simple, U-values can be defined in the object properties.
By the way, the tool for thermal bridges is quite simple to use, calculates proper values, but not the actual thermal bridge PSI value. The real value can be found by isolating parts of structures involved in thermal bridge and finding their PSI values.
