Teamwork & BIMcloud
A14 Travel Pack unload issue on PC
Created a travel pack from work under Mac.
Brought it home with A14 key and proceeded to unpack on a PC:
It reads:
Loading Travel Pack...
Unpacking Local Data
Process bar made it to 95% and suddenly...
pop up window:
Error while importing travel pack. Make sure the disk is not full or write protected and that the projects/libraries are not currently in use.
A co-worker had created a travel pack the same way and brought home to a Mac, worked perfectly.
I have checked the file's write protection and no issues with disk size etc.
Has anyone experienced the same unpacking issue on a PC????
Thanks.
rob2218
I just created a "travel and Pack" file.
did your issue get resolved?
How do you "work" on a travel and packed file at home, let's say?
do I have to "unpack" the travel and packed file (open it up in my home PC?)
I see you use archicad and are in Washington DC. Which firm?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
Eduardo Rolon
I just ran into this problem too. Travelpack created in Mac, opened in remote pack without problems. Did the same thing and cannot open it in AC14 running Win Xp.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
