Travel Pack import option missing in menu
I created a travel pack at the office. When home I open ArchiCad 14 (same build as in the office) to import the travel pack as instructed in the manual. Except there is no "Travel Pack" item in the menu for me to choose. I have read all the instructions about this but I cant find anything that answers my issue. What am I doing wrong?
EDIT: I found out it had to do with the menu-scheme. I successfully changed it and voilá there was the option to import Travel Pack.
Did you migrate your AC13 Work Environment to AC14?
The Teamwork menu is different in AC14.
You can see how it looks if you apply the "Standard 14" Work Environment.
