we are on a Mac OS X 10.6.3.
And I'm having a hellava time installing the BIM Server from the "Archicad Installer" folder off the server.
Problems that keep coming up are as follows:
1. When I try to select the "Browse for different folder" button to setup the location of the "project data" files as well as the "library files"....the mac wont allow me to continue.....has a major 'lock up - NOT RESPONDING' session on this one.
2. When I simply ignore this and type in the location on the server for project data files as well as the library files....then I reach the end where I'm to press the button that says "START BIM SERVER"...and no dice!!! doesn't work..locks up again.
Graphisoft whats going on here???
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
