Achille Pavlidis
Archicad 14 BIM server, only for Mac OSX 10.5 or typo again?
on the "Read me" file of the new AC 14 install cd, i read:
"Macintosh®
Software
Mac OSX 10.5, 10.6,
Mac OSX Server 10.5"
Is this correct, or it is again a typo?
Mac OS 26.1 | AC 29.1.0 INT 4006 FULL
7 Replies 7
Hi Achille,
I thought Ed Brown answered that question on the other thread?
http://archicad-talk.graphisoft.com/viewtopic.php?p=170987#170987
I guess there would have been no time to update the AC14 DVDs before they were sent out.
Achille Pavlidis
That was referred to AC 13 BIM Server...
i was asking about AC 14 BIM Server...
just for clarification purposes...
also, to be on the safe side...
has anyone installed AC 14 BIM Server on Mac OSX 10.6?
That's true.
It's probably wise to check after the problems you had before!
Hope it goes smoother this time.
Achille Pavlidis
Yes, i hope too!
But this time i'm not installing till someone has, and reports it works OK...
Ed_Brown
Graphisoft Alumni
Graphisoft Alumni
Where do I go to repent?
I have a Mac OS X Server 10.6 with ArchiCAD 14 on it. It is working fine.
Graphisoft Technical Support
Achille Pavlidis
OK Ed, thanks!
rob2218
we are on a Mac OS X 10.6.3.
And I'm having a hellava time installing the BIM Server from the "Archicad Installer" folder off the server.
Problems that keep coming up are as follows:
1. When I try to select the "Browse for different folder" button to setup the location of the "project data" files as well as the "library files"....the mac wont allow me to continue.....has a major 'lock up - NOT RESPONDING' session on this one.
2. When I simply ignore this and type in the location on the server for project data files as well as the library files....then I reach the end where I'm to press the button that says "START BIM SERVER"...and no dice!!! doesn't work..locks up again.
Graphisoft whats going on here???
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
