2014-06-24 05:00 PM
2014-06-25 03:24 PM
2014-06-25 05:00 PM
2014-06-25 05:01 PM
2014-06-26 03:48 PM
ksjhawk wrote:
I lied...it just worked. mhoude, go to reconfigure v18 module shortcut in location where you installed the BIM Server...this will give you the port number...type ip address and port number in as described by ejrolon above...hope this helps.
2014-06-26 03:54 PM
2014-06-27 05:46 PM
ejrolon wrote:I'm not getting it. There is no such reconfiguring file in the BIMSever folder. Only Server module 1700. I have a downloaded file from last year that updated the BIMServer. Is there one this year that I missed? or is it all in one .dmg file?
Check for it in ht BimServer folder in either your Application Folder or Program Folder.
I just found out that this is the one that is used to restart the server.
2014-06-27 05:50 PM
2014-06-30 10:17 AM
2014-06-30 10:21 AM
2014-06-30 12:59 PM
