archigreen
BIM SERVER STOPPED
I have recently updated my MAC OSX, but now my BIM SERVER stops working.
Every time I try to start again it stops after 10 seconds.
Should I uninstall the BIM SERVER to install it again?
Any Ideas?
Thank you so much. This Forum is being so helpful
Regards
Archigreen
ArchiCAD 26
MacOS Monterey
MacBook Pro Apple M1 Max
64 GB
Rod Jurich
Any Ideas?/.....
You said you updated your OS but have you applied the latest hotfix also?
I had similar woes after not correctly updating the BS.
Uninstalled BS,then installed and reapplied the hofix paying attention to the
installer instruction fixed a similar problem for me. All sweet now.
What gave me a clue was to check that BS was the same build number as ArchiCAD.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
