3 weeks ago
Because of new licensing protocol for Collaborate, I am in the process of migrating our company's old BIMcloud SAAS Server to the new one. In the process, I am cleaning out all of the old garbage projects that were lying around in there. Some are being deleted, but others we would like to archive in the event that something comes back to life in the future. Some of these projects date back to AC22, although I currently only have AC27 and above on my machine. When I attempt to join these old projects, an error tells me that it is on an old version and I need to update the source project first, as if it is a hotlink, which it is not. I am attaching the message I get below. Is there any way of getting around this without installing an old version of AC that will most likely not work due to my operating system?
Solved! Go to Solution.
3 weeks ago
You can't open an Archicad 24 teamwork project in Archicad 27 directly. For your archiving purpose, you have these options:
I'd definitely do the first two options, in my opinion this is the safest way to archive your older projects.
Noémi Balogh
Senior Community Expert, Admin
3 weeks ago
Noémi Balogh
3 weeks ago
Thanks for the help.
