Kooperative E45
BIMcloud Basic backup - Task manager can't run batch file
Hi everyone,
I migrated all our projects to a new server (a windows 10 workstation) but I can't figure out how to run a backup automatically. I am using a batch file from this link, which works perfectly when I run it manually but somehow there is no way to run it from Task Scheduler.
I tried the following:
- using the Administrator account
- using the System account
- adding the batch file path to the "start in" field in the Task settings
Question 1: Did anyone have the same problem  and managed to solve it?
Question 2: Would it be fine to just run a backup software and backup the folders at night while the server is running, so that I don't have to deal with batch files at all?
Thanks in advance to everyone who will have the patience to answer (:
0 Replies 0
