‎2019-12-16 11:21 AM
‎2019-12-16 11:58 AM
‎2019-12-16 12:03 PM
LaszloNagy wrote:
I do not speak this language, but that "Maps en HDR" probably means "HDR maps".
And I think that folder does not contain ARCHICAD Library Parts. It contains files that can be used as HDR (High Dynamic Range) images/backgrounds in CineRender. This is probably the reason why you don't donf any objects in it.
‎2019-12-16 02:43 PM
‎2019-12-16 03:38 PM
‎2019-12-16 03:57 PM
LaszloNagy wrote:
I tried this, although not on a BIM Server project, and indeed, the HDR Images library does display folders and those HDR files in the Library Manager Dialog.
I wonder if you deleted that folder from the BIM Server, then re-uploaded the folder and loaded it into the Project file, would that solve this issue?
‎2019-12-16 04:29 PM
‎2019-12-16 04:40 PM
mbl wrote:
What does it say in the Manage BIMcloud Libraries under "Modified"?
https://helpcenter.graphisoft.com/user-guide/88411/
I think that one of my colleagues had a similar problem with one of his BIMcloud Libraries in Archicad 22. The Library was showing in the Library Manager and it was showing its size, but the Library was "empty" in the file.
I don't remember what exactly solved it, but we started with Update BIMcloud Library command, which didn't help as far as I remember, so we ended up deleting the Library from BIMcloud and then uploading it again. I think that was what solved it for us at the end.
And also, what happens when you add the same BIMcloud Library to another file?
‎2019-12-16 04:59 PM
‎2019-12-16 05:16 PM
mbl wrote:
Hm, that's strange then. So there is no BIMcloud Library at all that can be updated? And does it keep the same "Modified" date even after you delete it and upload again?
