2019-12-16 11:21 AM
2019-12-16 08:28 PM
2019-12-16 09:13 PM
mbl wrote:
Do you need the library to be a .lcf file?
For the libraries, that have something to do only with that particular project, we have a "project library" subfolder under the project on the server and there we dump all the non-standard library parts. It's just "loose" .gdl files, project-specific textures and stuff like that, but they can be also sorted in folders for better orientation.
The whole "project library folder" is then Uploaded as a BIM Library. No .lcf.
It's quite easy to handle, it's just copying and pasting files in your file explorer. When something changes or we add a new object/texture/subfolder/..., it's usually just a simple update of that library in the Manage BIMcloud Libraries menu.
2019-12-16 10:27 PM
2019-12-16 10:37 PM
mbl wrote:
Sorry, I'm not being very clear. When I said a folder on a "server" I meant on a "network drive". And I meant a "regular" Windows or Mac folder with our library objects (or textures) that we keep in the project folder.
It can theoretically be also on your local drive, but usually more people need to access it too.
There is info on how to upload it to BIMcloud on the link I posted earlier. Under "Upload a Library to BIMcloud".
https://helpcenter.graphisoft.com/user-guide/88411/
2019-12-17 08:51 AM
2021-06-29 10:47 AM
2021-06-30 11:23 AM
AEismann wrote:
lcf exchange between 23/24 causes crashes (great work Graphisoft ! looking forward towards 25).
solution for this is to use native import-export of BIMcloud which would not result in graying out of the functionality of editing a library (great work Graphisoft).
2021-06-30 11:26 AM
2021-06-30 11:47 AM
2021-06-30 11:58 AM
LaszloNagy wrote:Its a small independent library we have (so not the standard or key membership edition we have) with a couple of objects and textures. I create a container from it using file > libraries and objects > create container.
One more question, just to be sure: So you upload your default AC23 library to BIMcloud and then add that LCF from BIMcloud to your AC24 Teamwork project? Which localized version is this?
