2021-09-28 01:27 PM
We currently run BIMcloud on a Hyper-V installation with several VM's.
There's the DC/Fileserver, the BIMcloud and a VM with our linux VoIP installation.
Apart from the VoIP, for which we have ongoing quality issues, everything seems to work fine most of the time.
There are moments however, when it appears that Teamwork projects do not load as quickly as normal. I can't point a finger on why that would happen, and maybe it is just nothing more than that, an idea that it is slower.
Any ideas on BIMcloud and mixed VM usage?
Pro's and Con's! Do's and Dont's!
2021-09-28 01:52 PM
I can't really give you pro's and con's, but can give you some tips what to check:
Noémi Balogh
Community Expert, Admin
2021-09-28 03:28 PM
Hi Noemi,
I will check these things in the next few days.
Can you elaborate on direct client access to the BIMcloud server? What do you mean by this?!
What defines a "one port only" communication?!
2021-09-28 03:57 PM
Open an Archicad and go to Teamwork > Project > Open / Join Teamwork Project... and on the server dropdown list, select 'Run Network Diagnostic Tool for <your BIMcloud's name>'.
Check the details: if you can see the BIMcloud Server on the list, or all addresses are red, then BIMcloud Server is not directly available from Archicad, and all communication goes through only the BIMcloud Manager. If it is good, then you see something similar like this:
Noémi Balogh
2021-09-28 04:08 PM
These are the settings for our BIMcloud installation.
2021-09-29 11:04 AM
This looks good, so I suggest to check the other settings I mentioned. 🙂
Noémi Balogh
