justdhruv
Bim server settings dissappear
This has happened to me me 4 times now that all of a sudden all BIM sevrer setup data, such as users and project just gets wiped out. Only the master admin can log in.
The project files are there in the folder but the server needs a new setup.
Is this common, or am i doing something wrongly. And is there any precaution one can take.
I would really like to request Graphisoft to make BIMserver painless. Currently the backup strategies require going into the terminal on the mac and the equivalent on windows.
Why can't it be simpler, and rock solid. Specially considering if the server goes down it can bring office work to a grinding halt.
ArchiCAD 20. MacBook Pro 17", 2010
+ core i7 4970k Hackintosh
3 Replies 3
schagemann
Never heard of the problem you are describing before - where does your BIM server run... on your MBPro?
Btw. there are plenty of threads here discussing the ins and outs of various backup strategies, including third party software - have a look around.
VKTRS | macinteract
Design Technology Managers - all on macOS | since AC 6
Archicad Framework > Smart Template 28
Smart Tree, Transmittal and Universal Label plus other smart GDL Objects
Marton Kiss
Try the instructions from here: http://helpcenter.graphisoft.com/?p=63211
Probably the db under the Manager component becomes corrupt.
Marton Kiss
Chief Product Officer
GRAPHISOFT
justdhruv
Thanks, that is exactly my problem.
But graphisoft should just automate all of this.
