Martin5
BimCloud server on Windows lags a lot computer in time
I am testing the Bimcloud server on a PC with Windows 10 and 11. It works without problems, including all other applications, but after some time (about 1 day) of running, the computer lags a lot. Applications (like Total Commander) take several minutes to launch on the desktop. It also takes a long time to restart or shut down the computer. But after restart everything works smoothly again. For some time. Another day is computer laggy again.
If Bimcloud is uninstalled, the computer runs smoothly for many days without any problems.
Is there a wrong setting somewhere? I tested on three Win10 and 11 computers in our office with the same results.
Thanks for help.
4 Replies 4
GAG
Do you have more technical details?
  • Windows version: not just major version (10 or 11), but specific build number (like 10.0.19045.4046).
  • BIMcloud version for Manager and Sever components (e.g. 2024.1, 28.0.567.5208).
  • Hardware specification (RAM, HDD, SSD).
  • Amount of CPU load and memory usage at startup and after observing system lag.
I suspect that some versions of BIMcloud may have leaked memory and this may have been fixed in later versions.
George
Martin5
Thanks for your respond.
Windows 11, 22H2, build 22621.3593
BimCloud Manager 2024.1 (28.0.567.5208)
BimCloud Server 28.0.567.5208
CPU i7-6700, 3,4 GHz
RAM 32 GB
OS SSD - Kingston SA400S37120G, 120GB, 37 GB free space
data HDD - WDC WD20EFRX-68EUZN0, 2TB, 1,25TB free space
PC stats with system lag:
PC stat in fresh state, when all is running smoothly:
Thanks for help.
Martin5
Now, after windows update last week, it looks OS runs fine.
Actual Windows build is Win11 22H2 build 22621.3737.
PC runs 3 days with no problem.
Martin5
So, after reboot, problem is back...
