2009-10-07 09:29 AM
2009-10-08 12:51 AM
2009-10-08 01:08 AM
2009-10-08 04:45 AM
2009-10-08 12:36 PM
2009-10-09 06:50 PM
2009-10-09 09:24 PM
R wrote:I do not know of a preference item that would cause the backups to be stored in a location separate from the project database. That could be useful.
I would like the database to be included in our daily Retrospect backup of the NAS server....
Will it be very inefficient to put the BIM server database on our NAS server? This will mean a double use of the network, every time someone does a send and receive, since all the data will first go to the BIM server workstation and then to the network NAS. However, the extra traffic may not matter, and this would give us the automatic backup we want.
Or, is there a way to specify a different network location for the BIM server backups?
2009-10-09 10:33 PM
2009-10-10 01:50 AM
R wrote:Look forward to reading about your experience down the road.
Thanks, Karl. We will do the experiment of storing the database remotely. This is a small test project, so it is not representative of what we may eventually need.
We are on Macs, but Time Machine doesn't have abilities to rotate backups to different drives to be kept off-site. We have used Retrospect reliably for years and it has saved our files at least twice. I wouldn't want to trust Time Machine to backup an important project.Maybe I've made a mess of things, but I've used two separate drives for TM and it seems to work fine ... when TM discovers a different drive than was last used, it just traverses the drive before doing a backup so that it knows what is new. I think. Maybe I've got gaps that I don't know about though. I have a tech-love thing for TM vs other backup software, and you know that love is blind...
Our rule is that everybody must send changes every night before leaving, or must copy their files to the server.Good plan.
I think I can set up an automated action on the BIM server workstation to copy the database file from the workstation to the NAS server on a daily basis, before the Retrospect backup runs.
As far as backing up the local ArchiCAD team member's working database copy (or what ever we are supposed to call it), I don't even know where it is kept. I searched for something with the project file name, and didn't find anything. Someone mentioned that maybe it isn't a file but is "bits and pieces of the database stored in various places". Do you know how to find the local information so it could be backed up?This was answered in another thread. The Work Environment specifies where the local TW data is saved - so you can either read the path there, or change it to someplace else.
2009-10-27 08:10 AM
