2025-02-10 08:37 AM
Bimcloud is local, not SaaS. Ldap sync has been used for years, only after 2024 installation the problem appeared for some users. Few of them did not meet the password requirements, but even after they changed their passwords they are denied access.
2025-03-26 09:19 AM
Absolutely.
I have to emphasize that I haven't tried it yet. It will need to wait in our office till the weekend.
The idea is that there is a chance, the portalServer saves the incorrect password in case of an invalid login attempt. (Graphisoft hasn't found the bug yet, but they assume this can cause it.)
Workaround:
The following parameter should be set in the PortalServerConfig.xml file:
<LdapUserAuthentication passwordExpireTime="0"/>
To apply the above workaround, follow the steps below:
Please note the Manager-XXXX-XX-XX indicates when the BIMcloud was installed e.g. 2025-03-21
Please let me know how you go. Thanks.
2025-04-02 02:25 AM
Hi All, I updated the PortalServerConfig.xml file over the weekend, no issues so far, but it is still early days. I think we need a few weeks without an incident to be confident that it is working.
I will keep you informed.
4 weeks ago
Seems that there is now an update but it does not mention to cure this problem.
In this version of BIMcloud, we introduce several new improvements and fixes for on-premises users, including:
This version of BIMcloud also includes all relevant fixes from previous BIMcloud SaaS versions since BIMcloud 2024.3.
