Teamwork & BIMcloud
Bimcloud delta cache
AngelWil
I have BIMCloud Saas. I'm trying to add on the Bimcloud Delta Cache. I've downloaded the Delta Cache and installed it. I've configured the file location to be on my C drive, the port, and the max size. Then i went into Archicad and opened the work environment network and update. This is where I'm stuck. I've tried to put in the address but its needing an http and not the folder address I created on the c drive. I've tried putting in my BIMcloud SaaS server address but it says it can't be found.
0 REPLIES 0
