Teamwork & BIMcloud
Can't uninstall BIM server
drh64
I ended up with the Bim server 13 and 14 on my system. I am now unable to remove either of them. See below. How can I get them removed?
4 REPLIES 4
Rod Jurich
drh64 wrote:
/... How can I get them removed?
I had a similar problem a while back Daniel.
See attached. Try this as it worked for me.
Do not delete these preferences, just put them on your desktop.
If this succeeds then trash the preferences.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
drh64
Thanks. I will try that!
drh64
It worked. Thanks again.
svpribyl
Thanks, Rod...this worked for me trying to uninstall Bim Server 14
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
