‎2015-08-28 03:30 PM
‎2015-08-28 08:06 PM
Important Note for Teamwork UsersSo this tells me you should be using build 5100.
- * Please DO NOT install this Update to client ARCHICAD applications which connect to BIMcloud.
* Working in Teamwork requires that client ARCHICADs and the BIM Server all have the identical version and build number. Please make sure that you update BIM Server along with the ARCHICAD client applications used in Teamwork.
